Ana içeriğe geç
Samsung Galaxy Mega Front Facing Camera Replacement
Neye ihtiyacın var
    1. Samsung Galaxy Mega Front Facing Camera Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Mega Front Facing Camera Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Mega Front Facing Camera Replacement, Battery: adım 1, 3 resimden 3.
      • Before starting, ensure device is completely turned off.
      • On the back of phone, locate the slot on the top left corner.
      • Insert plastic opening tool or fingernail and pull up on the back plate.
      • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Mega Front Facing Camera Replacement: adım 2, 3 resimden 1. Samsung Galaxy Mega Front Facing Camera Replacement: adım 2, 3 resimden 2. Samsung Galaxy Mega Front Facing Camera Replacement: adım 2, 3 resimden 3.
      • Insert fingernail into the slot on bottom of battery and gently pull up.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: adım 3, 3 resimden 1. Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: adım 3, 3 resimden 2. Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: adım 3, 3 resimden 3.
      • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
      • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
      • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Mega Front Facing Camera Replacement: adım 4, 2 resimden 1. Samsung Galaxy Mega Front Facing Camera Replacement: adım 4, 2 resimden 2.
      • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
      • The device should easily come apart after the plastic opening tool is slid around the entire device.
      • During reassembly, ensure volume and power buttons align properly.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy Mega Front Facing Camera Replacement, Front Facing Camera: adım 5, 1 resimden 1.
      • Remove the one 2.55 mm Phillips #000 screw from top left of motherboard assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Mega Front Facing Camera Replacement: adım 6, 1 resimden 1.
      • Remove metal cover with plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy Mega Front Facing Camera Replacement: adım 7, 2 resimden 1. Samsung Galaxy Mega Front Facing Camera Replacement: adım 7, 2 resimden 2.
      • Lift the motherboard connector and remove the camera assembly from phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Max Rathman
915 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G2
4 Üyeler
56 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 1,172
