Ana içeriğe geç
Samsung Galaxy Mega Midframe Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Mega Midframe Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Mega Midframe Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Mega Midframe Replacement, Battery: adım 1, 3 resimden 3.
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Midframe Replacement: adım 2, 3 resimden 1. Samsung Galaxy Mega Midframe Replacement: adım 2, 3 resimden 2. Samsung Galaxy Mega Midframe Replacement: adım 2, 3 resimden 3.
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Midframe Replacement, Midframe: adım 3, 3 resimden 1. Samsung Galaxy Mega Midframe Replacement, Midframe: adım 3, 3 resimden 2. Samsung Galaxy Mega Midframe Replacement, Midframe: adım 3, 3 resimden 3.
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Midframe Replacement: adım 4, 2 resimden 1. Samsung Galaxy Mega Midframe Replacement: adım 4, 2 resimden 2.
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Aaron Fulton
1.246 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 10
Her zaman: 1,124
