Ana içeriğe geç
Samsung Galaxy Mega Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Mega Motherboard Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Mega Motherboard Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Mega Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
    Bonjur vule vondre de telefon samsung galaxy mega ecron
    bucuresteanugigel - Yanıt
    samsung galaxi mega
    0751571718 samsung galaxi mega
  2. Samsung Galaxy Mega Motherboard Replacement: adım 2, 3 resimden 1. Samsung Galaxy Mega Motherboard Replacement: adım 2, 3 resimden 2. Samsung Galaxy Mega Motherboard Replacement: adım 2, 3 resimden 3.
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Motherboard Replacement, Midframe: adım 3, 3 resimden 1. Samsung Galaxy Mega Motherboard Replacement, Midframe: adım 3, 3 resimden 2. Samsung Galaxy Mega Motherboard Replacement, Midframe: adım 3, 3 resimden 3.
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
    If you insert a spudger from the battery compartment seam, you can start the opening without damage to the outside.
    Ted - Yanıt
  4. Samsung Galaxy Mega Motherboard Replacement: adım 4, 2 resimden 1. Samsung Galaxy Mega Motherboard Replacement: adım 4, 2 resimden 2.
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the 2.55 mm Phillips #000 screw from the motherboard panel.
  6. Samsung Galaxy Mega Motherboard Replacement: adım 6, 3 resimden 1. Samsung Galaxy Mega Motherboard Replacement: adım 6, 3 resimden 2. Samsung Galaxy Mega Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove the connector clips on motherboard.
  7. Samsung Galaxy Mega Motherboard Replacement: adım 7, 2 resimden 1. Samsung Galaxy Mega Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the final motherboard connectors.
  8. Samsung Galaxy Mega Motherboard Replacement: adım 8, 3 resimden 1. Samsung Galaxy Mega Motherboard Replacement: adım 8, 3 resimden 2. Samsung Galaxy Mega Motherboard Replacement: adım 8, 3 resimden 3.
    • Lift motherboard gently with finger.
    • There is a total of six connectors on the motherboard that need to be removed. All of them are shown in the pictures in this guide, make sure all of them are disconnected before removing.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Max Rathman
915 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G2
4 Üyeler
8 adet Kılavuz yazıldı
5 Yorum
Where can I buy a motherboard replacement for Mega 6.3 GT-I9205/I527?
valuesphilippines - Yanıt
Is there an international market to buy mobile phone hardware? I can not find motherboard for this phone in my country (online).
lukhman - Yanıt
Where can I buy the motherboard replacement for G. Mega 6.3 19200
Thats dae - Yanıt
i cant turn on my galay mega 6.3 afrer update phone is like DEAD!!!  please help me…..for Samsung mega gt-i9205
mirza baig - Yanıt
This app is the best
Mazen Noufal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 17
Her zaman: 5,498
