Ana içeriğe geç
Samsung Galaxy Mega Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Mega Rear Facing Camera Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Mega Rear Facing Camera Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Mega Rear Facing Camera Replacement, Battery: adım 1, 3 resimden 3.
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 2, 3 resimden 1. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 2, 3 resimden 2. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 2, 3 resimden 3.
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Rear Facing Camera Replacement, Midframe: adım 3, 3 resimden 1. Samsung Galaxy Mega Rear Facing Camera Replacement, Midframe: adım 3, 3 resimden 2. Samsung Galaxy Mega Rear Facing Camera Replacement, Midframe: adım 3, 3 resimden 3.
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 4, 2 resimden 1. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 4, 2 resimden 2.
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega Rear Facing Camera Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the 2.55 mm Phillips #000 screw from the motherboard panel.
  6. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 6, 3 resimden 1. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 6, 3 resimden 2. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 6, 3 resimden 3.
    • Remove the connector clips on motherboard.
  7. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 7, 2 resimden 1. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 7, 2 resimden 2.
    • Remove the final motherboard connectors.
  8. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 8, 3 resimden 1. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 8, 3 resimden 2. Samsung Galaxy Mega Rear Facing Camera Replacement: adım 8, 3 resimden 3.
    • Lift motherboard gently with finger.
    • There is a total of six connectors on the motherboard that need to be removed. All of them are shown in the pictures in this guide, make sure all of them are disconnected before removing.
  9. Samsung Galaxy Mega Rear Facing Camera Replacement, Rear Facing Camera: adım 9, 2 resimden 1. Samsung Galaxy Mega Rear Facing Camera Replacement, Rear Facing Camera: adım 9, 2 resimden 2.
    • On the back of the motherboard, remove the connector of the rear facing camera from the motherboard.
    • Camera is now detached from device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Max Rathman
915 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 685
