Ana içeriğe geç
Samsung Galaxy Mega Speaker Assmebly Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: adım 1, 3 resimden 3.
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Speaker Assmebly Replacement: adım 2, 3 resimden 1. Samsung Galaxy Mega Speaker Assmebly Replacement: adım 2, 3 resimden 2. Samsung Galaxy Mega Speaker Assmebly Replacement: adım 2, 3 resimden 3.
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: adım 3, 3 resimden 1. Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: adım 3, 3 resimden 2. Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: adım 3, 3 resimden 3.
    • Remove the 6 3.45 mm Phillips #000 screws from the bottom of the assembly surrounding the speaker.
    • Gently insert plastic opening tool through the inside groove of the speaker assembly.
    • Once the top part of the speaker assembly pops free. Gently lift up with your fingers to remove speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
nithin
137 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G2
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 927
