Ana içeriğe geç
Samsung Galaxy Mega USB Board Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Mega USB Board Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Mega USB Board Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Mega USB Board Replacement, Battery: adım 1, 3 resimden 3.
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy Mega USB Board Replacement: adım 2, 3 resimden 1. Samsung Galaxy Mega USB Board Replacement: adım 2, 3 resimden 2. Samsung Galaxy Mega USB Board Replacement: adım 2, 3 resimden 3.
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy Mega USB Board Replacement, Midframe: adım 3, 3 resimden 1. Samsung Galaxy Mega USB Board Replacement, Midframe: adım 3, 3 resimden 2. Samsung Galaxy Mega USB Board Replacement, Midframe: adım 3, 3 resimden 3.
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy Mega USB Board Replacement: adım 4, 2 resimden 1. Samsung Galaxy Mega USB Board Replacement: adım 4, 2 resimden 2.
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy Mega USB Board Replacement, USB Board: adım 5, 1 resimden 1.
    • This circuit board is the charging port assembly.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy Mega USB Board Replacement: adım 6, 3 resimden 1. Samsung Galaxy Mega USB Board Replacement: adım 6, 3 resimden 2. Samsung Galaxy Mega USB Board Replacement: adım 6, 3 resimden 3.
    • Lift up on the clamp with your finger to disconnect the connector.
    • Lift up on the clamp with your finger to disconnect the connection to the mother board.
    • Grasp cable head and lift up to disconnect the cable head.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy Mega USB Board Replacement: adım 7, 2 resimden 1. Samsung Galaxy Mega USB Board Replacement: adım 7, 2 resimden 2.
    • Use your fingers to gently remove charging port.
    FixBot'a Sor
    Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Aaron Fulton
1.246 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G2
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 9,121
