Giriş
Is your phone cracked? Or is the screen dark?
Then, this awesome guide will help you replace your screen!
Neye ihtiyacın var
You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
This is when a new battery will be inserted.
Bu adımda kullanılan alet:Tweezers$4.99
With your tweezers remove the bottom circuit from the screen.
6 farklı kişi bu kılavuzu tamamladı.
