Giriş
Trying to replace the screen, incl. digitizer.
It is based on
and
Actually you need only to remove the battery but I removed the motherboard etc. for safety reasons.
Neye ihtiyacın var
Bu adımda kullanılan alet:Spudger$2.99
Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
Bu adımda kullanılan alet:Phillips #000 Screwdriver$5.49
Remove the six 3mm screws around the battery with the Phillips PH000 screwdriver.
Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
Remove the one 3mm screw on the top left side of the device with the same method.
Remove the gray rubber piece.
Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
Remove the right speaker unit.
rub of the glue with the fingers
remove residues with makeup remover or similar
9 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
is the digitizer glued to the lcd screen?
it is see referenced YouTube video
The e battery and screen cable clasps that hold tge cables in….. Where do i get them repaired
Hi can somebody help me
