Ana içeriğe geç
Samsung Galaxy Note 10.1 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: adım 1, 3 resimden 1. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: adım 1, 3 resimden 2. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: adım 1, 3 resimden 3.
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: adım 2, 3 resimden 1. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: adım 2, 3 resimden 2. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: adım 2, 3 resimden 3.
    • Unscrew the three screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: adım 3, 3 resimden 1. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: adım 3, 3 resimden 2. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: adım 3, 3 resimden 3.
    • Start by lifting the white connector to remove the part indicated by the red polygon.
    • Gently pry along the camera hub to lift it out of its location.
    • This is your camera. Replace it with the new part.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bryan Fernandez
241 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-7, Brown Fall 2014 USF Tampa, Team 3-7, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G7
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 2,200
