Ana içeriğe geç
Samsung Galaxy Note 10.1 microSD Port Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: adım 1, 3 resimden 1. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: adım 1, 3 resimden 2. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: adım 1, 3 resimden 3.
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: adım 2, 3 resimden 1. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: adım 2, 3 resimden 2. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: adım 2, 3 resimden 3.
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: adım 3, 3 resimden 1. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: adım 3, 3 resimden 2. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: adım 3, 3 resimden 3.
    • Unscrew the two 2 mm screws indicated by the red circles with the #00 Philips Screwdriver.
    • Starting with the black motherboard connector, remove the module indicated by the red box in the second picture.
    • Replace the microSD port with a similar model.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Tyler Salomone
1.020 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-7, Brown Fall 2014 USF Tampa, Team 3-7, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G7
3 Üyeler
9 adet Kılavuz yazıldı
2 Yorum
Be sure to include screw lengths to the nearest mm on all guides.
Dan Brown - Yanıt
In this guide, you missed a step on removing the battery.
John Peterson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 3,917
