Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide explains the way to replacing the headphone jack.
  1. Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Slide your fingernail or plastic opening tool along the edge of the rear case. Lift the case gently from the base.
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
  3. Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base. Lift the battery out of its recess.
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Place your fingernail in the groove of the stylus pen.
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Remove the twelve 4mm Phillips #00 screws from the back chassis.
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  7. Insert the plastic opening tool into the Stylus Pen placement holder.
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  8. Remove the single screw beside headphone jack. Remove the single screw beside headphone jack.
    • Remove the single screw beside headphone jack.
  9. Use tweezers to remove both antenna clips. Use a spudger to disconnect six cable connectors.
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  10. Pull up on the motherboard with tweezers.
    • Pull up on the motherboard with tweezers.
  11. Insert the spudger into the headphone jack.
    • Insert the spudger into the headphone jack.
  12. Lift the spudger to separate the jack assembly from the motherboard.
    • Lift the spudger to separate the jack assembly from the motherboard.
    • Pull to remove.
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
Brittany Gail
8.318 İtibar
8 adet Kılavuz yazıldı
Takım
USF Tampa, Team 2-2, Blackwell Fall 2014 USF Tampa, Team 2-2, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S2G2
4 Üyeler
25 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 13,930
