Ana içeriğe geç
Samsung Galaxy Note 3 Headphone Jack Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove the rear case: adım 1, 1 resimden 1.
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Case from the Base: adım 2, 2 resimden 1. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Case from the Base: adım 2, 2 resimden 2.
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
  3. Samsung Galaxy Note 3 Headphone Jack Replacement, Battery: adım 3, 2 resimden 1. Samsung Galaxy Note 3 Headphone Jack Replacement, Battery: adım 3, 2 resimden 2.
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Headphone Jack Replacement, S Pen: adım 4, 1 resimden 1.
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Headphone Jack Replacement, Unscrew Back Chassis: adım 5, 1 resimden 1.
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Back Chassis: adım 6, 1 resimden 1.
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Headphone Jack Replacement, Screw Removal: adım 7, 2 resimden 1. Samsung Galaxy Note 3 Headphone Jack Replacement, Screw Removal: adım 7, 2 resimden 2.
    • Remove the single screw beside headphone jack.
  8. Samsung Galaxy Note 3 Headphone Jack Replacement, Unfasten Clips and Cable Connectors: adım 8, 2 resimden 1. Samsung Galaxy Note 3 Headphone Jack Replacement, Unfasten Clips and Cable Connectors: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Headphone Jack Replacement, Motherboard Removal: adım 9, 1 resimden 1.
    • Pull up on the motherboard with tweezers.
  10. Samsung Galaxy Note 3 Headphone Jack Replacement, Spudger Tool Placement: adım 10, 1 resimden 1.
    • Insert the spudger into the headphone jack.
  11. Samsung Galaxy Note 3 Headphone Jack Replacement, Lift to Separate Headphone Jack: adım 11, 1 resimden 1.
    • Lift the spudger to separate the jack assembly from the motherboard.
    • Pull to remove.
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
Brittany Gail
8.539 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2014 USF Tampa, Team 2-2, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S2G2
4 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 15,377
