Ana içeriğe geç
Samsung Galaxy Note 3 Midframe Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note 3 Midframe Replacement, Remove the rear case: adım 1, 1 resimden 1.
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Midframe Replacement, Remove Case from the Base: adım 2, 2 resimden 1. Samsung Galaxy Note 3 Midframe Replacement, Remove Case from the Base: adım 2, 2 resimden 2.
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Why... is it not simple enough already lol
    Adam Ahmed - Yanıt
  3. Samsung Galaxy Note 3 Midframe Replacement, Battery: adım 3, 2 resimden 1. Samsung Galaxy Note 3 Midframe Replacement, Battery: adım 3, 2 resimden 2.
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Midframe Replacement, S Pen: adım 4, 1 resimden 1.
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Midframe Replacement, Unscrew Back Chassis: adım 5, 1 resimden 1.
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Midframe Replacement, Remove Back Chassis: adım 6, 1 resimden 1.
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
Sonuç
48 farklı kişi bu kılavuzu tamamladı.
Brittany Gail
8.504 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2014 USF Tampa, Team 2-2, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S2G2
4 Üyeler
25 adet Kılavuz yazıldı
2 Yorum
the info provided is perfectly narrated and illustrated, however this guide is incomplete and potentially misleading. unintentionally im sure..
the guide is titled "Mid Frame Replacement" and all this guide tells you is how to remove the rear frame (still 2 separate components) it has made no mention of the fact the mid-frame is fused to the screen assembly nor any of the ribbon/cables thats quite possibly may affect the reader, and im afraid some may order a mid frame thinking they can handle this, only to be puzzled when the back comes off and they are left pondering what next.. im not trying to be spiteful, you guys are amazing and i always check your guides before a repair/swap ect that ive not done before to make sure i dont miss a hidden ribbon cable or device specific shortcut, im simply trying to look for the beginners that are aspiring to become one of ..
That being said love the site guys!! keep up teh good work, i use you at least a half dozen times a week :)
regards,
vick0den
shane walker - Yanıt
i know i need to know how to remove the mid frame from the lcd as i need to replace mine its cracked on the outside and i dont want to break my lcd as i need it still , this guide sucks.
Kenneth A - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 19,348
