Ana içeriğe geç
Samsung Galaxy Note 3 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note 3 Motherboard Replacement, Remove the rear case: adım 1, 1 resimden 1.
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Motherboard Replacement, Remove Case from the Base: adım 2, 2 resimden 1. Samsung Galaxy Note 3 Motherboard Replacement, Remove Case from the Base: adım 2, 2 resimden 2.
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
  3. Samsung Galaxy Note 3 Motherboard Replacement, Battery: adım 3, 2 resimden 1. Samsung Galaxy Note 3 Motherboard Replacement, Battery: adım 3, 2 resimden 2.
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Motherboard Replacement, S Pen: adım 4, 1 resimden 1.
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Motherboard Replacement, Unscrew Back Chassis: adım 5, 1 resimden 1.
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Motherboard Replacement, Remove Back Chassis: adım 6, 1 resimden 1.
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Motherboard Replacement, Screw Removal: adım 7, 2 resimden 1. Samsung Galaxy Note 3 Motherboard Replacement, Screw Removal: adım 7, 2 resimden 2.
    • Remove the single screw beside headphone jack.
  8. Samsung Galaxy Note 3 Motherboard Replacement, Unfasten Clips and Cable Connectors: adım 8, 2 resimden 1. Samsung Galaxy Note 3 Motherboard Replacement, Unfasten Clips and Cable Connectors: adım 8, 2 resimden 2.
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Motherboard Replacement, Motherboard Removal: adım 9, 1 resimden 1.
    • Pull up on the motherboard with tweezers.
Sonuç
74 farklı kişi bu kılavuzu tamamladı.
Brittany Gail
8.504 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2014 USF Tampa, Team 2-2, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S2G2
4 Üyeler
25 adet Kılavuz yazıldı
4 Yorum
I'm looking for the screws for this phone, but all the search hits I've come across are for the screwdriver. Any leads on where I can find the screws?
Jared Lunt - Yanıt
I can replace motherboard sm-n9005 with motherboard sm-n900
yacine - Yanıt
I want to replace motherboard of galaxy note 3 SM-N900 with SM-N9005. Is it possible and can it convert 3g to 4G. Because my phone doesn't support 4G .it is 3g and I want to make it 4G .what should I do help me
Nippy Preet -
I am also looking for the same question
Jalil Ahmad -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 43
Her zaman: 50,495
