Ana içeriğe geç
Samsung Galaxy Note 3 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove the rear case: adım 1, 1 resimden 1.
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: adım 2, 2 resimden 1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: adım 2, 2 resimden 2.
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Why... is it not simple enough already lol
    Adam Ahmed - Yanıt
  3. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: adım 3, 2 resimden 1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: adım 3, 2 resimden 2.
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Rear Facing Camera Replacement, S Pen: adım 4, 1 resimden 1.
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unscrew Back Chassis: adım 5, 1 resimden 1.
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Back Chassis: adım 6, 1 resimden 1.
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: adım 7, 2 resimden 1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: adım 7, 2 resimden 2.
    • Remove the single screw beside headphone jack.
    You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
    Oriol Felisart - Yanıt
  8. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: adım 8, 2 resimden 1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: adım 8, 2 resimden 2.
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Motherboard Removal: adım 9, 1 resimden 1.
    • Pull up on the motherboard with tweezers.
    Can i change at&t board to 9002 or 9005??,
    Ayyaz - Yanıt
    My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
    soha Javed - Yanıt
    My wifi hotspot is not working
    Kiran Thopate - Yanıt
  10. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unclipping the Camera: adım 10, 1 resimden 1.
    • Unclip the camera connecting cable using the plastic opening tool from the motherboard
    • Remove loose camera from base
Sonuç
37 farklı kişi bu kılavuzu tamamladı.
Brittany Gail
8.504 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2014 USF Tampa, Team 2-2, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S2G2
4 Üyeler
25 adet Kılavuz yazıldı
3 Yorum
Awesome, phone disassembly and fingernail painting at same time :) Thanks for your time to post this!
Chris G - Yanıt
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
hameidfehri - Yanıt
I shall be very thankfull for this act of kindness
Malik wajdan ali - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 13,428
