Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
Giriş
If you cannot connect the Samsung Galaxy Note 4 to the cellular network, or a Wi-Fi network, you may need to replace the antenna. Follow this guide to replace the antenna in your Samsung Galaxy Note 4.
  1. Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  2. Insert a plastic opening tool between the midframe and the display assembly. Work the plastic opening tool around the perimeter of the phone to break the adhesive. This adhesive is relatively weak, so no heat gun should be necessary.
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  3. Use a plastic opening tool to loosen the clasps around the battery housing.
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  4. Push on the battery housing to separate the midframe from the display assembly. You will have to apply a reasonable amount of pressure to separate the two parts. If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  5. Pull up on the connectors with tweezers to detach them from the phone. The blue dot on the shorter connector belongs nearest the bottom of the phone.
    • Pull up on the connectors with tweezers to detach them from the phone.
    • The blue dot on the shorter connector belongs nearest the bottom of the phone.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Derek Nola
2.049 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 70-6, Forte Winter 2015 Cal Poly, Team 70-6, Forte Winter 2015 üyesi
CPSU-FORTE-W15S70G6
4 Üyeler
15 adet Kılavuz yazıldı
6 Yorum
hi where can i buy an antenna connector ?
i live in india.
ramumohan007 - Yanıt
Google kar le
ravi raj -
I broke the actual ports that the antenna cables connect to on the mother board. Is thereally away to fix them or do I have to replace the whole logic/motherboard? I would like to keep my logic/motherboard because I don't want to lose all my text messages. What should I do?
shanonsmitt16 - Yanıt
I also broke the connector component on the motherboard. It remains attached to the blue cable. Could this be re-soldered?
Leanahtan Eiddiwnid - Yanıt
Is there a make shift way to put a extra antenna using one the two antenna ports above and to the left of the standard antenna cable. Without make any holes on the housing its self
Pedro A Sosa - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 164
Her zaman: 19,504
