Ana içeriğe geç
Samsung Galaxy Note 4 Antenna Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note 4 Antenna Replacement, Midframe: adım 1, 1 resimden 1.
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  2. Samsung Galaxy Note 4 Antenna Replacement: adım 2, 3 resimden 1. Samsung Galaxy Note 4 Antenna Replacement: adım 2, 3 resimden 2. Samsung Galaxy Note 4 Antenna Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  3. Samsung Galaxy Note 4 Antenna Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  4. Samsung Galaxy Note 4 Antenna Replacement: adım 4, 3 resimden 1. Samsung Galaxy Note 4 Antenna Replacement: adım 4, 3 resimden 2. Samsung Galaxy Note 4 Antenna Replacement: adım 4, 3 resimden 3.
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  5. Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: adım 5, 2 resimden 1. Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: adım 5, 2 resimden 2.
    • Pull up on the connectors with tweezers to detach them from the phone.
    • The blue dot on the shorter connector belongs nearest the bottom of the phone.
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Derek Nola
2.244 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 70-6, Forte Winter 2015 Cal Poly, Team 70-6, Forte Winter 2015 üyesi
CPSU-FORTE-W15S70G6
4 Üyeler
16 adet Kılavuz yazıldı
6 Yorum
hi where can i buy an antenna connector ?
i live in india.
ramumohan007 - Yanıt
Google kar le
ravi raj -
I broke the actual ports that the antenna cables connect to on the mother board. Is thereally away to fix them or do I have to replace the whole logic/motherboard? I would like to keep my logic/motherboard because I don't want to lose all my text messages. What should I do?
shanonsmitt16 - Yanıt
I also broke the connector component on the motherboard. It remains attached to the blue cable. Could this be re-soldered?
Leanahtan Eiddiwnid - Yanıt
Is there a make shift way to put a extra antenna using one the two antenna ports above and to the left of the standard antenna cable. Without make any holes on the housing its self
Pedro A Sosa - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 18
Her zaman: 23,312
