Giriş
Use this guide to replace the headphone jack on your Samsung Galaxy Note 4.
Neye ihtiyacın var
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery.
Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Grasp the cap of the S Pen and remove it from its slot in the midframe.
Bu adımda kullanılan alet:Tweezers$4.99
Use the plastic spudger and tweezers to remove the headphone jack from the middle housing.
21 farklı kişi bu kılavuzu tamamladı.
