Ana içeriğe geç
Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement, Micro-USB Port Daughterboard: adım 1, 3 resimden 1. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement, Micro-USB Port Daughterboard: adım 1, 3 resimden 2. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement, Micro-USB Port Daughterboard: adım 1, 3 resimden 3.
    • Use a fingernail or vinyl spudger to easily remove the back cover of the device. Remove the S-Pen, battery, SIM card and MicroSD card (if present).
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 2, 3 resimden 1. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 2, 3 resimden 2. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 2, 3 resimden 3.
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 3, 2 resimden 1. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 3, 2 resimden 2.
    • Heat with a low degree and cut the sticker along the side of touch panel.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 4, 3 resimden 1. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 4, 3 resimden 2. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 4, 3 resimden 3.
    • Free the clasps along the battery slot. And the push the front assembly out from middle housing with effort.
    • We can see the USB board but we can't tear it down directly. Because 1. The USB board flex connector is connecting on the back of the motherboard. 2. If want to remove motherboard, the LCD screen need to be removed at first. 3. The USB board assembly comes with two touch keys together but they are placed under the touch panel.
    • So we have to remove the motherboard and LCD screen at first next.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 5, 3 resimden 1. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 5, 3 resimden 2. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 5, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 6, 2 resimden 1. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 6, 2 resimden 2.
    • Remove two pcs of signal flex cable and two screws which securing USB board and motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 7, 2 resimden 1. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 7, 2 resimden 2.
    • Release all the connectors connecting with motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 8, 2 resimden 1. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 8, 2 resimden 2.
    • Pry up the motherboard and release USB board connector from back.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 9, 2 resimden 1. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: adım 9, 2 resimden 2.
    • Loosen the touch keys from adhesive at first. And then pry up and remove the USB board finally.
    • It's complicated to do Samsung Galaxy Note 4 USB board assembly replacement. We have to replace the LCD screen and motherboard at first, please be careful.
    FixBot'a Sor
    Yorum Ekle
Sonuç
55 farklı kişi bu kılavuzu tamamladı.
Sophia
43.911 İtibar
62 adet Kılavuz yazıldı
9Kılavuz Yorumları
why do you need to take the full LCD off risking it braking. You could just heat the bottom and separate the touch buttons and home button.
Subzero - Yanıt Paylaş
Does the daughter board handle the touch fuction of the key or the light only?
George - Yanıt Paylaş
charging port from 910C will be suitable to 910F model? Pls answer
Artsiom Tratsiak - Yanıt Paylaş
After replacing USB ass'y, my AT&T phone does not recognize the Sim being installed.
Any suggestions?
Dan
Daniel Cameron - Yanıt Paylaş
I advice anyone going to attempt this to not take the full LCD off or you will be paying out another £140 for a new screen.
Also save your self time don't take the motherboard out.
ICanFixIt - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 85
Her zaman: 75,288
