Ana içeriğe geç
Samsung Galaxy Note 5 Back Cover Replacement
Neye ihtiyacın var
Videoya Genel Bakış
    1. Samsung Galaxy Note 5 Back Cover Replacement, Samsung Galaxy Note 5 Back Cover Replacement: adım 1, 1 resimden 1.
      • Heat the back cover to melt the strong adhesive sticker underneath.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Note 5 Back Cover Replacement: adım 2, 1 resimden 1.
      • Try to pull and open a gap between back cover and frame after heat. Insert into a guitar pick to cut the sticker.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy Note 5 Back Cover Replacement: adım 3, 1 resimden 1.
      • If you do it hardly, you need much more heat especially the edged side.
      • Slipping a playing card through the gap is a good way to loosen up the adhesive.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy Note 5 Back Cover Replacement: adım 4, 1 resimden 1.
      • Remove the back cover. The white stripe is the sticker.
      FixBot'a Sor
      Yorum Ekle
Sonuç
45 farklı kişi bu kılavuzu tamamladı.
Sophia
43.911 İtibar
62 adet Kılavuz yazıldı
9Kılavuz Yorumları
What about putting the one back on?
rcf917 - Yanıt Paylaş
will it go back on and stay on without new adhesive?
dfasdfjiun - Yanıt Paylaş
I suggest that you take new adhesive, old adhesive is not strong enough to hold back cover.
Witrigs - Yanıt Paylaş
You can check this video of put it back battery cover : https://www.youtube.com/watch?v=3HrmeVGY...
How do I remove the sticky part
Marcelino Lopez - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 51
Her zaman: 109,883
