Ana içeriğe geç
Samsung Galaxy Note Edge Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note Edge Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Power down your device and make sure that it is turned off.
    • Place the phone with the screen facing down on a clean flat surface.
  2. Samsung Galaxy Note Edge Motherboard Replacement: adım 2, 3 resimden 1. Samsung Galaxy Note Edge Motherboard Replacement: adım 2, 3 resimden 2. Samsung Galaxy Note Edge Motherboard Replacement: adım 2, 3 resimden 3.
    • Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
    • Remove battery by using your Supdger on the notch located directly underneath battery location.
    • During the creation of this guide, we did not have access to a battery in our device.
  3. Samsung Galaxy Note Edge Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
    • Remove the stylus from the stylus holder.
  4. Samsung Galaxy Note Edge Motherboard Replacement: adım 4, 3 resimden 1. Samsung Galaxy Note Edge Motherboard Replacement: adım 4, 3 resimden 2. Samsung Galaxy Note Edge Motherboard Replacement: adım 4, 3 resimden 3.
    • Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
    • Insert your spudger into the stylus socket and pry the midframe from the phone.
    • Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
  5. Samsung Galaxy Note Edge Motherboard Replacement: adım 5, 2 resimden 1. Samsung Galaxy Note Edge Motherboard Replacement: adım 5, 2 resimden 2.
    • With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone.
    • Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
  6. Samsung Galaxy Note Edge Motherboard Replacement: adım 6, 3 resimden 1. Samsung Galaxy Note Edge Motherboard Replacement: adım 6, 3 resimden 2. Samsung Galaxy Note Edge Motherboard Replacement: adım 6, 3 resimden 3.
    • Using your Spudger's pointed end, pry off the following leads that connect these parts to the logic board in the top left hand corner:
    • Front Facing Camera
    • AMOLED Display Screen
    • AMOLED Capacitive Screen
  7. Samsung Galaxy Note Edge Motherboard Replacement: adım 7, 3 resimden 1. Samsung Galaxy Note Edge Motherboard Replacement: adım 7, 3 resimden 2. Samsung Galaxy Note Edge Motherboard Replacement: adım 7, 3 resimden 3.
    • At the top end, gently insert pointed end of spudger underneath the motherboard.
    • Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard.
    • Remove the motherboard from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Matt Clark
157 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G6, Maness Spring 2018 Cal Poly, Team S22-G6, Maness Spring 2018 üyesi
CPSU-MANESS-S18S22G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 3,549
