Giriş
If you are unable to adjust the volume on your device, the volume switch may be faulty. Use this guide to replace the volume button in your device.
Neye ihtiyacın var
Place your device flat down on a clean surface.
Use a Spudger to remove the back cover using the notch at the top left.
Neredeyse bitti!
Sonuç
