Ana içeriğe geç
Samsung Galaxy Note Edge Volume Button Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: adım 1, 2 resimden 1. Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: adım 1, 2 resimden 2.
    • Place your device flat down on a clean surface.
    • Use a Spudger to remove the back cover using the notch at the top left.
    FixBot'a Sor
  2. Samsung Galaxy Note Edge Volume Button Replacement: adım 2, 1 resimden 1.
    • Use a Spudger to remove the battery using the notch located underneath the battery.
    • Note: During the creation of this guide, we did not have access to a battery.
    FixBot'a Sor
  3. Samsung Galaxy Note Edge Volume Button Replacement: adım 3, 1 resimden 1.
    • Remove the stylus from its sheathe.
    FixBot'a Sor
  4. Samsung Galaxy Note Edge Volume Button Replacement: adım 4, 1 resimden 1.
    • Use a Philips #000 Screwdriver to remove the fifteen 4mm screws.
    FixBot'a Sor
  5. Samsung Galaxy Note Edge Volume Button Replacement: adım 5, 1 resimden 1.
    • Use a Spudger to remove the black chassis and expose the motherboard.
    FixBot'a Sor
  6. Samsung Galaxy Note Edge Volume Button Replacement: adım 6, 3 resimden 1. Samsung Galaxy Note Edge Volume Button Replacement: adım 6, 3 resimden 2. Samsung Galaxy Note Edge Volume Button Replacement: adım 6, 3 resimden 3.
    • Use a Spudger to disconnect the following connections:
    • Connection 1
    • Connection 2
    • Connection 3
    FixBot'a Sor
  7. Samsung Galaxy Note Edge Volume Button Replacement: adım 7, 1 resimden 1.
    • Remove the connection for the front camera.
    FixBot'a Sor
  8. Samsung Galaxy Note Edge Volume Button Replacement: adım 8, 3 resimden 1. Samsung Galaxy Note Edge Volume Button Replacement: adım 8, 3 resimden 2. Samsung Galaxy Note Edge Volume Button Replacement: adım 8, 3 resimden 3.
    • Do not try to completely remove the motherboard until the final step.
    • Use a Spudger to gently lift the motherboard.
    • Remove the connection of the motherboard and the daughter board.
    • Remove the motherboard.
    FixBot'a Sor
  9. Samsung Galaxy Note Edge Volume Button Replacement: adım 9, 3 resimden 1. Samsung Galaxy Note Edge Volume Button Replacement: adım 9, 3 resimden 2. Samsung Galaxy Note Edge Volume Button Replacement: adım 9, 3 resimden 3.
    • Remove the volume button panel.
    • Remove the volume button connection.
    • Remove the volume button entirely.
    FixBot'a Sor
Sonuç
Lizzie Todd
301 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Harley Spring 2019 IUPUI, Team S1-G1, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S1G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 45
Her zaman: 645
