Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace the headphone jack and earpiece speaker assembly of your Samsung Galaxy Note.
Neye ihtiyacın var
Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
Insert your finger in the notch of the battery compartment.
Press the battery toward the rear facing camera while pulling outward.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly connector.
12 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I'd recommend getting an Original part if possible, the knock off speaker has no metal casing where the original does.
