Ana içeriğe geç
Giriş
Use this guide to remove the back cover. This guide is a prerequisite for many other guides. You may need to remove the midframe if your need to install a new antenna, Micro USB port, headphone jack and earpiece, or replace the motherboard.
  1. Make sure the screen is face-down and the camera is opposite you. Insert the flat end of a spudger into the phone's top right rectangular slot. Use the spudger as a lever to pry open the back of the phone.
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
  2. With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
  3. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  4. Place the spudger in the battery's bottom right slot.
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
  5. Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
    • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
  6. Remove the stylus from the bottom of the phone.
    • Remove the stylus from the bottom of the phone.
  7. Pry all the way around the sides with a plastic pry tool and gently pop off the midframe. If the cover does not come off easily, continue to pry along the phone's perimeter. This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
    • If the cover does not come off easily, continue to pry along the phone's perimeter.
    • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Separate the midframe from the phone. The midframe should now pull off easily.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
David Ritter
758 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team 3-45, Amido Spring 2013 Cal Poly, Team 3-45, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G45
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,991
