Ana içeriğe geç
Samsung Galaxy Note Midframe Replacement
Neye ihtiyacın var
    1. Samsung Galaxy Note Midframe Replacement, Rear Case: adım 1, 2 resimden 1. Samsung Galaxy Note Midframe Replacement, Rear Case: adım 1, 2 resimden 2.
      • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Note Midframe Replacement: adım 2, 2 resimden 1. Samsung Galaxy Note Midframe Replacement: adım 2, 2 resimden 2.
      • Lift and remove the rear case from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy Note Midframe Replacement, Battery: adım 3, 2 resimden 1. Samsung Galaxy Note Midframe Replacement, Battery: adım 3, 2 resimden 2.
      • Insert your finger in the notch of the battery compartment.
      • Press the battery toward the rear facing camera while pulling outward.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy Note Midframe Replacement, MicroSD Card: adım 4, 3 resimden 1. Samsung Galaxy Note Midframe Replacement, MicroSD Card: adım 4, 3 resimden 2. Samsung Galaxy Note Midframe Replacement, MicroSD Card: adım 4, 3 resimden 3.
      • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • For reassembly, push the microSD card into the slot until it clicks in place.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Note Midframe Replacement: adım 5, 1 resimden 1.
      • Remove the microSD card from its slot in the midframe.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy Note Midframe Replacement, SIM Card: adım 6, 2 resimden 1. Samsung Galaxy Note Midframe Replacement, SIM Card: adım 6, 2 resimden 2.
      • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Note Midframe Replacement: adım 7, 2 resimden 1. Samsung Galaxy Note Midframe Replacement: adım 7, 2 resimden 2.
      • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy Note Midframe Replacement, Midframe: adım 8, 1 resimden 1.
      • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Note Midframe Replacement: adım 9, 2 resimden 1. Samsung Galaxy Note Midframe Replacement: adım 9, 2 resimden 2.
      • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy Note Midframe Replacement: adım 10, 3 resimden 1. Samsung Galaxy Note Midframe Replacement: adım 10, 3 resimden 2. Samsung Galaxy Note Midframe Replacement: adım 10, 3 resimden 3.
      • Slide the plastic opening tool down the seam.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy Note Midframe Replacement: adım 11, 3 resimden 1. Samsung Galaxy Note Midframe Replacement: adım 11, 3 resimden 2. Samsung Galaxy Note Midframe Replacement: adım 11, 3 resimden 3.
      • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
      • Slide the opening tool along the top edge of the phone.
      • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Galaxy Note Midframe Replacement: adım 12, 2 resimden 1. Samsung Galaxy Note Midframe Replacement: adım 12, 2 resimden 2.
      • Remove the midframe from the display assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.842 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
49.860 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 11,437
