Ana içeriğe geç
Samsung Galaxy Note Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note Motherboard Replacement, Stylus: adım 1, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement, Stylus: adım 1, 2 resimden 2.
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Motherboard Replacement, Rear Case: adım 2, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement, Rear Case: adım 2, 2 resimden 2.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Motherboard Replacement: adım 3, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement: adım 3, 2 resimden 2.
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Motherboard Replacement, Battery: adım 4, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement, Battery: adım 4, 2 resimden 2.
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Motherboard Replacement, MicroSD Card: adım 5, 3 resimden 1. Samsung Galaxy Note Motherboard Replacement, MicroSD Card: adım 5, 3 resimden 2. Samsung Galaxy Note Motherboard Replacement, MicroSD Card: adım 5, 3 resimden 3.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Motherboard Replacement, SIM Card: adım 7, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement, SIM Card: adım 7, 2 resimden 2.
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Motherboard Replacement: adım 8, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement: adım 8, 2 resimden 2.
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Motherboard Replacement, Midframe: adım 9, 1 resimden 1.
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Motherboard Replacement: adım 10, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement: adım 10, 2 resimden 2.
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Motherboard Replacement: adım 11, 3 resimden 1. Samsung Galaxy Note Motherboard Replacement: adım 11, 3 resimden 2. Samsung Galaxy Note Motherboard Replacement: adım 11, 3 resimden 3.
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Motherboard Replacement: adım 12, 3 resimden 1. Samsung Galaxy Note Motherboard Replacement: adım 12, 3 resimden 2. Samsung Galaxy Note Motherboard Replacement: adım 12, 3 resimden 3.
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Motherboard Replacement: adım 13, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement: adım 13, 2 resimden 2.
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Motherboard Replacement, Motherboard Assembly: adım 14, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement, Motherboard Assembly: adım 14, 2 resimden 2.
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note Motherboard Replacement: adım 15, 3 resimden 1. Samsung Galaxy Note Motherboard Replacement: adım 15, 3 resimden 2. Samsung Galaxy Note Motherboard Replacement: adım 15, 3 resimden 3.
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note Motherboard Replacement: adım 16, 3 resimden 1. Samsung Galaxy Note Motherboard Replacement: adım 16, 3 resimden 2. Samsung Galaxy Note Motherboard Replacement: adım 16, 3 resimden 3.
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note Motherboard Replacement: adım 18, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement: adım 18, 2 resimden 2.
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note Motherboard Replacement, Rear Facing Camera: adım 19, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement, Rear Facing Camera: adım 19, 2 resimden 2.
    • Use a plastic opening tool to flip the release tab on the rear-facing camera cable ZIF connector.
    • Only pry on the tab, not the connector itself.
    What's the wiring diagram for board and camets
    Blanca - Yanıt
    What'd the camera wiring diagram or board diagram
    Blanca - Yanıt
  20. Samsung Galaxy Note Motherboard Replacement: adım 20, 2 resimden 1. Samsung Galaxy Note Motherboard Replacement: adım 20, 2 resimden 2.
    • Slide the tip of a spudger under the rear-facing camera cable to slide it out of the ZIF connector and free it from the light adhesive.
  21. Samsung Galaxy Note Motherboard Replacement: adım 21, 1 resimden 1.
    • Remove the rear-facing camera.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
465.777 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
4 Yorum
from where I can get the motherboard for Samsung Galaxy note 3???
abdom911 - Yanıt
Can You Assist Me where can I purchase samsung GT- N7000 mother board. GALAXY NOTE 1
edcas2158 - Yanıt
i need note 7000 motherboard
rajeev kapoor - Yanıt
How much does it cost for buying a Samsung Galaxy Note4 motherboard ? And where will I get it in Bangalore
LIGHT BREEZE - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 36,727
