Ana içeriğe geç
Samsung Galaxy Note Pro 12.2 Audio Jack Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement, Audio Jack: adım 1, 1 resimden 1.
    • Make sure that your device is powered off before starting your repair.
    • Carefully remove the back cover with the blue opening tool.
    • It is best to start with one corner and work your way around the device slowly.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: adım 2, 2 resimden 1. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: adım 2, 2 resimden 2.
    • Remove the two 3mm Phillips #00 screws securing in the white cover over the audio jack.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: adım 3, 1 resimden 1.
    • Remove the white cover over the audio jack with the plastic opening tool by pushing up on the black connecter.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: adım 4, 2 resimden 1. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: adım 4, 2 resimden 2.
    • Remove the two 3mm Phillips #00 screws over the silver cover.
    • The silver cover is attached to the whole audio jack; do not try to pull this away by itself.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: adım 5, 2 resimden 1. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: adım 5, 2 resimden 2.
    • Pop up the green connecter by gently pulling up.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: adım 6, 2 resimden 1. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: adım 6, 2 resimden 2.
    • Pull up on the circular amp with the spudger tool to release it from the device.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: adım 7, 1 resimden 1.
    • Remove the whole audio jack by pulling gently up on the copper piece.
    • This component is extremely fragile.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 33
Her zaman: 965
