Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Carefully remove the back cover with the blue opening tool.
Remove the two 3mm Phillips #00 screws securing in the white cover over the audio jack.
Remove the white cover over the audio jack with the plastic opening tool by pushing up on the black connecter.
Remove the two 3mm Phillips #00 screws over the silver cover.
Pull up on the circular amp with the spudger tool to release it from the device.
Remove the whole audio jack by pulling gently up on the copper piece.
