Ana içeriğe geç
Samsung Galaxy Note Pro 12.2 Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note Pro 12.2 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the device is powered off before starting repair.
    • Carefully remove the back cover with the blue opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 Battery Replacement: adım 2, 3 resimden 1. Samsung Galaxy Note Pro 12.2 Battery Replacement: adım 2, 3 resimden 2. Samsung Galaxy Note Pro 12.2 Battery Replacement: adım 2, 3 resimden 3.
    • You may have a piece of tape covering your strips, make sure to remove them before starting this step.
    • Flip open the black tabs that are securing the black strips across the battery. This may require the plastic opening tool.
  3. Samsung Galaxy Note Pro 12.2 Battery Replacement: adım 3, 2 resimden 1. Samsung Galaxy Note Pro 12.2 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the eight 3mm Phillips #00 screws surrounding the battery.
    • The screws are very small, use a magnetic board to keep track of all loose screws.
  4. Samsung Galaxy Note Pro 12.2 Battery Replacement: adım 4, 2 resimden 1. Samsung Galaxy Note Pro 12.2 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the battery connecter by gently pulling up with your finger.
  5. Samsung Galaxy Note Pro 12.2 Battery Replacement: adım 5, 1 resimden 1.
    • Once the battery is free, gently remove the battery from the device.
    • The battery and the connecters are fragile, so use caution when removing it from the device.
    Compré una batería en amazon y la instalé con esta Guía. La Guía muy bien. La compra muy mal. Tuve que volver a reinstalar la batería vieja. ¿DÓNDE O A QUIÉN COMPRAR UNA BUENA BATERIA NUEVA QUE FUNCIONE?
    Luis - Yanıt
Sonuç
24 farklı kişi bu kılavuzu tamamladı.
11 Yorum
Dearest Tina,
My first project. My first iFIXIT membership. Thank you sincerely. Love my Galaxy Note Pro 12.2 tablet.
Was told to trash it and get a new one. I say bunk to that. Purchased a brand new OEM battery and found you.
I feel so empowered. Thank you so much. For what you do is not just a job. It is a liberation for people like me.
You change lives. Remember that. The instructions are awesome with pictures to boot.
Sincerely Yours,
Christopher George
Christopher George - Yanıt
Dearest Christopher,
I am so glad you were able to repair your device using the guide! This was for a college course and I didn’t realize how desperate people were for good guides like these until doing this project. I really feel that this project was worth doing because people, like you, don’t want to waste their devices. Being able to fix something yourself is liberating like you said!
Thank you for you comment, felt nice knowing I helped at least one person!
-Tina
Tina Kong -
where to get Samsung Galaxy 12’’pro battery ?
Thanks
y1sunny1 - Yanıt
What a great resource you have. I ran into a disaster. Our Note 12.2 was a replacement for another Samsung tablet that was a lemon. Finally after three attempts to repair the lemon, we asked for our money back. Instead, we were promised a new unit.The new unit, the 12.2 wouldn’t charge and we sent it back. It finally came back great and worked for years but then the battery needed to be replaced. When I opened it up, I tried to disconnect the battery connector from the motherboard jack and the entire assembly came off the motherboard, I realized this a refurb and that the battery connector had been soldered to the motherboard jack and could not be disconnected. So now I have a useless motherboard. Arrgh!!!! Would love to see a Motherboard replacement video.
Doug Marlowe - Yanıt
Dear Tina, can you help me. I have bought new battery but my tablet didn’t work with it. So I have other than battery problem. The screen is black. Device does not respond. But the back of it is heating up. How do you think why? And what can I do?
lerue - Yanıt
Hi lerue. I have changed the battery in my 12.2 pro and had a similar outcome. So I took the back off again and found that I had not pushed the cable connectors in far enough. There are white lines for the alignment, which must correspond together. Maybe you have done the same!!!!
Good luck……. Telstar tez
terry_n_carol - Yanıt
Thank you very much
Samy Elshennawy - Yanıt
My note pro 12.2 tab battery terminal pulled off from the mother board. I was able to resolder the positive and negative but the BSI (GREEN MIDDLE BATTERY WIRE) is the problem as i cant solder it cause it have no terminal on the mainboard. Any help here on how to trace the thermistor line to the battery wire?
dd4sure@gmail.com
Godswill Eke - Yanıt
My Samsung galaxy notepro 12.2 started blinking and goes off, when powered again, it works like there is no problem but on the course of usage it blinks again and goes off. What could possible be the cause of that? I seriously need a help on the way out.
Ezekiel Sathmak - Yanıt
très bien, bravo
Al Hubert - Yanıt
Hi,
I have tried to replace the battery carefully following your excellent directions, but when taking off the right side black leads the plastic connector broke in three parts - the plastic had degraded. Where can I buy replacement connector?
Thank you.
Linda
sacredspace4u - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 57
Her zaman: 12,727
