Ana içeriğe geç
Samsung Galaxy Note Pro 12.2 SD Port Replacement
  1. Samsung Galaxy Note Pro 12.2 SD Port Replacement, SD Port: adım 1, 1 resimden 1.
    • Turn off your device before starting your repair.
    • Carefully remove the back cover with the plastic opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 SD Port Replacement: adım 2, 2 resimden 1. Samsung Galaxy Note Pro 12.2 SD Port Replacement: adım 2, 2 resimden 2.
    • Pop up the orange tab connected to the SD port with the plastic opening tool.
  3. Samsung Galaxy Note Pro 12.2 SD Port Replacement: adım 3, 2 resimden 1. Samsung Galaxy Note Pro 12.2 SD Port Replacement: adım 3, 2 resimden 2.
    • Remove the one 3mm Phillips #00 screw connected to the SD port.
  4. Samsung Galaxy Note Pro 12.2 SD Port Replacement: adım 4, 2 resimden 1. Samsung Galaxy Note Pro 12.2 SD Port Replacement: adım 4, 2 resimden 2.
    • Pop open the orange wire tab connected to the SD port with the plastic opening tool.
    • If there is tape covering your tab, remove it with the tweezers before you pop open the tab.
  5. Samsung Galaxy Note Pro 12.2 SD Port Replacement: adım 5, 2 resimden 1. Samsung Galaxy Note Pro 12.2 SD Port Replacement: adım 5, 2 resimden 2.
    • Using the orange tab, pull the SD port up and away from the device.
  6. Samsung Galaxy Note Pro 12.2 SD Port Replacement: adım 6, 1 resimden 1.
    • Using the plastic end of the tweezers pop up the orange tab connecting the SD port to the device.
    • There is a little indent below the orange tab to help get under this piece. It may be difficult to remove, push up hard.
Sonuç
Tina Kong
1.254 İtibar
5 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 457
