Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Carefully remove the back cover with the plastic opening tool.
Pop up the orange tab connected to the SD port with the plastic opening tool.
Remove the one 3mm Phillips #00 screw connected to the SD port.
Pop open the orange wire tab connected to the SD port with the plastic opening tool.
Using the orange tab, pull the SD port up and away from the device.
Using the plastic end of the tweezers pop up the orange tab connecting the SD port to the device.
