Ana içeriğe geç
Samsung Galaxy Note Pro 12.2 USB Port Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note Pro 12.2 USB Port Replacement, USB Port: adım 1, 1 resimden 1.
    • Make sure the device is off before starting your repair.
    • Carefully remove the back cover with the plastic opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 USB Port Replacement: adım 2, 1 resimden 1.
    • Using your finger, push up on the clip to disconnect from the device.
  3. Samsung Galaxy Note Pro 12.2 USB Port Replacement: adım 3, 2 resimden 1. Samsung Galaxy Note Pro 12.2 USB Port Replacement: adım 3, 2 resimden 2.
    • Remove the two 3mm screws from the silver cover using the Phillips #00 screwdriver.
  4. Samsung Galaxy Note Pro 12.2 USB Port Replacement: adım 4, 2 resimden 1. Samsung Galaxy Note Pro 12.2 USB Port Replacement: adım 4, 2 resimden 2.
    • Pop open the orange tab that is connected to the SD port using the plastic opening tool.
  5. Samsung Galaxy Note Pro 12.2 USB Port Replacement: adım 5, 1 resimden 1.
    • Pop up the USB port with the plastic opening tool.
    • Make sure that you are pushing up from underneath the part and not placing the tool inside the USB port itself.
  6. Samsung Galaxy Note Pro 12.2 USB Port Replacement: adım 6, 2 resimden 1. Samsung Galaxy Note Pro 12.2 USB Port Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, carefully lift away the orange piece connected to the USB port.
    • This piece is glued down. Be careful as you peel it away from the device.
    Please add links to where we can buy the replacement part.
    Doug Marlowe - Yanıt
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
5 Yorum
I have a problem with my note pro 12.2 wifi. The battery connector is broken and needs to be replaced on the motherboard. I want to do it right but can find No information online about removing the motherboard (I have found one that is very good for the 10.1) but there are cables on the 12.2 not on the 10.1 that I am not sure how to remove them.
Wayne De Groot - Yanıt
How about a battery connector replacement for the note pro 12.2 SM-P900 on motherboard.
Great instruction set and photos. I was a little nervous cracking it open for the first time (not as bad as the first time I upgraded my PC, but close), but your pictures and instructions were aces! It would have gone easier if I’d realized earlier that clicking on the photos popped them out to a separate tab where I could zoom, but I figured that out soon enough. The general concensus on the opener tools are that they don’t last long. I’d have to agree with that. Mine took a beating trying to get the back off, but with your instructions, it’s fixed. Thanks!
Carol Lapp - Yanıt
I lost the two screws. What size are they and where can I purchase them? Thank you.
Russell Ichenberg - Yanıt
very good instructions, was very helpful.
But it's still makes trouble charging.
Can it be any other problem or reason? Something doing the opposite of loading, very frustrating.
Daniela Chrzanowski - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 4,109
