Ana içeriğe geç
Samsung Galaxy Note SM-P600 Battery Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Samsung Galaxy Note SM-P600 Battery Replacement, Begin repair: adım 1, 1 resimden 1.
    • To start, power down your device
  2. Samsung Galaxy Note SM-P600 Battery Replacement, Removing the plastic back: adım 2, 2 resimden 1. Samsung Galaxy Note SM-P600 Battery Replacement, Removing the plastic back: adım 2, 2 resimden 2.
    • Carefully insert either a plastic pry tool or an iSesamo around the edges to pop the plastic clips free, allowing the seperation of the rear cover. You may need to go around all four edges a few times till you feel it begin to lift. Again, this step must be completed very carefully to avoid damaging the display or the buttons located on the sides.
  3. Samsung Galaxy Note SM-P600 Battery Replacement, Removing ribbon cables covering battery: adım 3, 3 resimden 1. Samsung Galaxy Note SM-P600 Battery Replacement, Removing ribbon cables covering battery: adım 3, 3 resimden 2. Samsung Galaxy Note SM-P600 Battery Replacement, Removing ribbon cables covering battery: adım 3, 3 resimden 3.
    • Using no plastic spudger, push the zif connector on each ribbon cable to release them. Then use the plastic spudger to slide under the cable with the black adhesive tape to remove it. Use a pair of tweezers to remove the silver tape on the top of the other cable.
  4. Samsung Galaxy Note SM-P600 Battery Replacement, Disconnecting the battery: adım 4, 3 resimden 1. Samsung Galaxy Note SM-P600 Battery Replacement, Disconnecting the battery: adım 4, 3 resimden 2. Samsung Galaxy Note SM-P600 Battery Replacement, Disconnecting the battery: adım 4, 3 resimden 3.
    • Remove the kapton tape located on the connector of the battery. Use the spudger to release the battery connector. Do this carefully as it is a tight connection. Then remove the 6 screws located along the sides, they are the same length and thread so their return spots are not an issue. Lift out the battery and the reverse steps to reinstall.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
dwales
611 İtibar
1 Kılavuz yazıldı
2 Yorum
dewales -- Thank you for an outstanding tutorial. You helped me to revive my beloved Note 10.1 ed. 2014.
Preston - Yanıt
Thanks! This worked!
Vera - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 5,397
