Giriş
Use this guide to replace your Samsung galaxy Note's speaker.
Parçalar
Hiçbir parça belirtilmedi.
Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
Insert your finger in the notch of the battery compartment.
Press the battery toward the rear facing camera while pulling outward.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
6 farklı kişi bu kılavuzu tamamladı.
