Ana içeriğe geç
Samsung Galaxy Note USB Board Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note USB Board Replacement, Stylus: adım 1, 2 resimden 1. Samsung Galaxy Note USB Board Replacement, Stylus: adım 1, 2 resimden 2.
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy Note USB Board Replacement, Rear Case: adım 2, 2 resimden 1. Samsung Galaxy Note USB Board Replacement, Rear Case: adım 2, 2 resimden 2.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy Note USB Board Replacement: adım 3, 2 resimden 1. Samsung Galaxy Note USB Board Replacement: adım 3, 2 resimden 2.
    • Lift and remove the rear case from the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy Note USB Board Replacement, Battery: adım 4, 2 resimden 1. Samsung Galaxy Note USB Board Replacement, Battery: adım 4, 2 resimden 2.
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy Note USB Board Replacement, MicroSD Card: adım 5, 3 resimden 1. Samsung Galaxy Note USB Board Replacement, MicroSD Card: adım 5, 3 resimden 2. Samsung Galaxy Note USB Board Replacement, MicroSD Card: adım 5, 3 resimden 3.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy Note USB Board Replacement: adım 6, 1 resimden 1.
    • Remove the microSD card from its slot in the midframe.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy Note USB Board Replacement, SIM Card: adım 7, 2 resimden 1. Samsung Galaxy Note USB Board Replacement, SIM Card: adım 7, 2 resimden 2.
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Galaxy Note USB Board Replacement: adım 8, 2 resimden 1. Samsung Galaxy Note USB Board Replacement: adım 8, 2 resimden 2.
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Galaxy Note USB Board Replacement, Midframe: adım 9, 1 resimden 1.
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Galaxy Note USB Board Replacement: adım 10, 2 resimden 1. Samsung Galaxy Note USB Board Replacement: adım 10, 2 resimden 2.
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Galaxy Note USB Board Replacement: adım 11, 3 resimden 1. Samsung Galaxy Note USB Board Replacement: adım 11, 3 resimden 2. Samsung Galaxy Note USB Board Replacement: adım 11, 3 resimden 3.
    • Slide the plastic opening tool down the seam.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Galaxy Note USB Board Replacement: adım 12, 3 resimden 1. Samsung Galaxy Note USB Board Replacement: adım 12, 3 resimden 2. Samsung Galaxy Note USB Board Replacement: adım 12, 3 resimden 3.
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Galaxy Note USB Board Replacement: adım 13, 2 resimden 1. Samsung Galaxy Note USB Board Replacement: adım 13, 2 resimden 2.
    • Remove the midframe from the display assembly.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: adım 14, 2 resimden 1. Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: adım 14, 2 resimden 2.
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Galaxy Note USB Board Replacement: adım 15, 3 resimden 1. Samsung Galaxy Note USB Board Replacement: adım 15, 3 resimden 2. Samsung Galaxy Note USB Board Replacement: adım 15, 3 resimden 3.
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
    FixBot'a Sor
    Yorum Ekle
  16. Samsung Galaxy Note USB Board Replacement: adım 16, 3 resimden 1. Samsung Galaxy Note USB Board Replacement: adım 16, 3 resimden 2. Samsung Galaxy Note USB Board Replacement: adım 16, 3 resimden 3.
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
    FixBot'a Sor
    Yorum Ekle
  17. Samsung Galaxy Note USB Board Replacement: adım 17, 1 resimden 1.
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
    FixBot'a Sor
    Yorum Ekle
  18. Samsung Galaxy Note USB Board Replacement: adım 18, 2 resimden 1. Samsung Galaxy Note USB Board Replacement: adım 18, 2 resimden 2.
    • Remove the motherboard assembly from the display assembly.
    FixBot'a Sor
    Yorum Ekle
  19. Samsung Galaxy Note USB Board Replacement, USB Board: adım 19, 1 resimden 1.
    • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
    FixBot'a Sor
    Yorum Ekle
  20. Samsung Galaxy Note USB Board Replacement: adım 20, 1 resimden 1.
    • Lift the speaker enclosure from the display assembly.
    FixBot'a Sor
    Yorum Ekle
  21. Samsung Galaxy Note USB Board Replacement: adım 21, 2 resimden 1. Samsung Galaxy Note USB Board Replacement: adım 21, 2 resimden 2.
    • Use the tip of a spudger to disconnect the antenna cable connector from the USB board.
    • Remove the antenna cable.
    FixBot'a Sor
    Yorum Ekle
  22. Samsung Galaxy Note USB Board Replacement: adım 22, 3 resimden 1. Samsung Galaxy Note USB Board Replacement: adım 22, 3 resimden 2. Samsung Galaxy Note USB Board Replacement: adım 22, 3 resimden 3.
    • Push the flat end of a spudger under the USB board to separate it from the display assembly.
    • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
    FixBot'a Sor
    Yorum Ekle
  23. Samsung Galaxy Note USB Board Replacement: adım 23, 1 resimden 1.
    • Remove the USB board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
51 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.674 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
27.624 adet Kılavuz yazıldı
6Kılavuz Yorumları
Using the Guides on online and the PDF guides made this repair easy and quick!
Joe - Yanıt Paylaş
It's not necessary to remove the motherboard (steps 17 and 18) to complete this repair. The flat flex running to the USB board can be easily slid out from under the motherboard with the motherboard still in position. Just omit steps 17 and 18 and the rest of the procedure works fine. I've done it twice.
Phil - Yanıt Paylaş
Where in England could I buy the USB Board part?
Craig Pyle - Yanıt Paylaş
USB board bought off ebay. Didnt need plastic opening tools, thumb nail worked easier than expected.
john dingley - Yanıt Paylaş
It's not the Galaxy Note GT-N7000!
costantino - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 25,108
