Ana içeriğe geç
Samsung Galaxy Note5 Display Replacement
Neye ihtiyacın var
    1. Samsung Galaxy Note5 Display Replacement, SIM Card Tray: adım 1, 1 resimden 1.
      • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
      • Press down until the SIM Card Tray begins to protrude out of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Note5 Display Replacement: adım 2, 1 resimden 1.
      • Remove the SIM Card Tray from the slot.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Galaxy Note5 Display Replacement, Display: adım 3, 1 resimden 1.
      • Heat the back of the device with a heat gun for two minutes.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Note5 Display Replacement: adım 4, 1 resimden 1.
      • Once the device is very warm to the touch, place a suction cup near the bottom of the back of the device.
      • Make sure to place the suction cup on the flat part of the glass.
      • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
      • While pulling upwards, insert a pick under the rear glass
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy Note5 Display Replacement: adım 5, 1 resimden 1.
      • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy Note5 Display Replacement: adım 6, 1 resimden 1.
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Galaxy Note5 Display Replacement: adım 7, 1 resimden 1.
      • Once all adhesive has been cut, gently lift up the rear glass to remove it.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Galaxy Note5 Display Replacement: adım 8, 1 resimden 1.
      • Remove the S-Pen from the bottom of the device.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung Galaxy Note5 Display Replacement: adım 9, 2 resimden 1. Samsung Galaxy Note5 Display Replacement: adım 9, 2 resimden 2.
      • Remove 20 5mm screws with a Phillips #1 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    8. Samsung Galaxy Note5 Display Replacement: adım 10, 3 resimden 1. Samsung Galaxy Note5 Display Replacement: adım 10, 3 resimden 2. Samsung Galaxy Note5 Display Replacement: adım 10, 3 resimden 3.
      • Grip the back of the device and press down on the white square to remove the middle housing.
      FixBot'a Sor
      Yorum Ekle
    9. Samsung Galaxy Note5 Display Replacement: adım 11, 1 resimden 1.
      • Loosen the two signal cable connectors.
      FixBot'a Sor
      Yorum Ekle
    10. Samsung Galaxy Note5 Display Replacement: adım 12, 3 resimden 1. Samsung Galaxy Note5 Display Replacement: adım 12, 3 resimden 2. Samsung Galaxy Note5 Display Replacement: adım 12, 3 resimden 3.
      Bu adımda kullanılan alet:
      • To disconnect flexes, carefully pull up on the exposed tab with tweezers.
      • Disconnect the battery flex.
      • Disconnect the earpiece flex.
      FixBot'a Sor
      Yorum Ekle
    11. Samsung Galaxy Note5 Display Replacement: adım 13, 1 resimden 1.
      • Remove the teal navigation button flex.
      FixBot'a Sor
      Yorum Ekle
    12. Samsung Galaxy Note5 Display Replacement: adım 14, 1 resimden 1.
      • Gently lift up the motherboard from the top end to remove.
      • Make sure all flexes are disconnected before removing the motherboard. If the motherboard does not easily detach, remove any connected flexes.
      FixBot'a Sor
      Yorum Ekle
    13. Samsung Galaxy Note5 Display Replacement: adım 15, 3 resimden 1. Samsung Galaxy Note5 Display Replacement: adım 15, 3 resimden 2. Samsung Galaxy Note5 Display Replacement: adım 15, 3 resimden 3.
      • With the motherboard removed, slowly pry off the battery with tweezers, starting at the bottom.
      • Be careful not to puncture the battery as this could cause permanent damage.
      FixBot'a Sor
      Yorum Ekle
    14. Samsung Galaxy Note5 Display Replacement: adım 16, 1 resimden 1.
      • Heat the display for two minutes with a heat gun.
      FixBot'a Sor
      Yorum Ekle
    15. Samsung Galaxy Note5 Display Replacement: adım 17, 1 resimden 1.
      • Once the display is very warm to the touch, slide a pick between the LCD and the LCD shield on the bottom edge of the device.
      • Slide the pick across the bottom to cut through the adhesive.
      FixBot'a Sor
      Yorum Ekle
    16. Samsung Galaxy Note5 Display Replacement: adım 18, 1 resimden 1.
      • The display is now removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
41 farklı kişi bu kılavuzu tamamladı.
Alexander Laucius
1.662 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G17, Maness Spring 2018 Cal Poly, Team S25-G17, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G17
4 Üyeler
46 adet Kılavuz yazıldı
6Kılavuz Yorumları
Worked like a charm
Ronald Sapp - Yanıt Paylaş
How does one bond everything back together?
lcplthomasc - Yanıt Paylaş
I am working in fixing my own Note 5. I have heard that double-sided tape made specifically for this task are best. You can find different options here: https://www.magazingsm.ro/adeziv-geam-si...
Cristina - Yanıt Paylaş
I have now replaced the display on my Note 5 and actually I didn’t even use the glue I bought. The original glue is quite a lot and the new display comes with glue on the back of it. Thanks again, Alexander, for your helpful instructions!
This was very helpful. Many thanks to the author. may God add many years to his life.
Peterson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 32
Son 30 gün: 102
Her zaman: 27,115
