Ana içeriğe geç
Samsung Galaxy Note5 Display Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note5 Display Replacement, SIM Card Tray: adım 1, 1 resimden 1.
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Display Replacement: adım 2, 1 resimden 1.
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Display Replacement, Display: adım 3, 1 resimden 1.
    • Heat the back of the device with a heat gun for two minutes.
  4. Samsung Galaxy Note5 Display Replacement: adım 4, 1 resimden 1.
    • Once the device is very warm to the touch, place a suction cup near the bottom of the back of the device.
    • Make sure to place the suction cup on the flat part of the glass.
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
    Ouch Didn't get it hot enough? Hopefully you ordered the back plate too, luckily they ain't too expensive
    Tuan Bui - Yanıt
  5. Samsung Galaxy Note5 Display Replacement: adım 5, 1 resimden 1.
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Display Replacement: adım 6, 1 resimden 1.
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Display Replacement: adım 7, 1 resimden 1.
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Display Replacement: adım 8, 1 resimden 1.
    • Remove the S-Pen from the bottom of the device.
  9. Samsung Galaxy Note5 Display Replacement: adım 9, 2 resimden 1. Samsung Galaxy Note5 Display Replacement: adım 9, 2 resimden 2.
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
    Phillips #0 in my particular case?
    Emmanuel Garcia - Yanıt
  10. Samsung Galaxy Note5 Display Replacement: adım 10, 3 resimden 1. Samsung Galaxy Note5 Display Replacement: adım 10, 3 resimden 2. Samsung Galaxy Note5 Display Replacement: adım 10, 3 resimden 3.
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Display Replacement: adım 11, 1 resimden 1.
    • Loosen the two signal cable connectors.
    Not the ones at the bottom but the ones connected to the mainboard
  12. Samsung Galaxy Note5 Display Replacement: adım 12, 3 resimden 1. Samsung Galaxy Note5 Display Replacement: adım 12, 3 resimden 2. Samsung Galaxy Note5 Display Replacement: adım 12, 3 resimden 3.
    • To disconnect flexes, carefully pull up on the exposed tab with tweezers.
    • Disconnect the battery flex.
    • Disconnect the earpiece flex.
    There‘s a bunch more flex cables to disconnect that are not shown here. Refer to Mainboard Replacement Guide for further details.
  13. Samsung Galaxy Note5 Display Replacement: adım 13, 1 resimden 1.
    • Remove the teal navigation button flex.
  14. Samsung Galaxy Note5 Display Replacement: adım 14, 1 resimden 1.
    • Gently lift up the motherboard from the top end to remove.
    • Make sure all flexes are disconnected before removing the motherboard. If the motherboard does not easily detach, remove any connected flexes.
  15. Samsung Galaxy Note5 Display Replacement: adım 15, 3 resimden 1. Samsung Galaxy Note5 Display Replacement: adım 15, 3 resimden 2. Samsung Galaxy Note5 Display Replacement: adım 15, 3 resimden 3.
    • With the motherboard removed, slowly pry off the battery with tweezers, starting at the bottom.
    • Be careful not to puncture the battery as this could cause permanent damage.
    I use a curled plastic guitar pick to get underneath the battery. It’s a really bad idea to use metal tools for this.
    Bryan Rought - Yanıt
    +1 here, I used the plastic spudger, still a bit sketchy without heating. i guess a little bit of heat from the screen side would help soften the adhesive
    Jimmy Beaudoin -
  16. Samsung Galaxy Note5 Display Replacement: adım 16, 1 resimden 1.
    • Heat the display for two minutes with a heat gun.
  17. Samsung Galaxy Note5 Display Replacement: adım 17, 1 resimden 1.
    • Once the display is very warm to the touch, slide a pick between the LCD and the LCD shield on the bottom edge of the device.
    • Slide the pick across the bottom to cut through the adhesive.
  18. Samsung Galaxy Note5 Display Replacement: adım 18, 1 resimden 1.
    • The display is now removed.
Sonuç
37 farklı kişi bu kılavuzu tamamladı.
Alexander Laucius
1.536 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G17, Maness Spring 2018 Cal Poly, Team S25-G17, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G17
4 Üyeler
5 adet Kılavuz yazıldı
6 Yorum
Worked like a charm
Ronald Sapp - Yanıt
How does one bond everything back together?
lcplthomasc - Yanıt
I am working in fixing my own Note 5. I have heard that double-sided tape made specifically for this task are best. You can find different options here: https://www.magazingsm.ro/adeziv-geam-si...
Cristina -
I have now replaced the display on my Note 5 and actually I didn’t even use the glue I bought. The original glue is quite a lot and the new display comes with glue on the back of it. Thanks again, Alexander, for your helpful instructions!
Cristina -
This was very helpful. Many thanks to the author. may God add many years to his life.
Peterson - Yanıt
You say no u hing about being careful about the switches ribbon cables or thr push button. I guess you assume that it come as part of the screen assembly. Will it doesn't. Complete moron to leave a step out of the instructions.
Dick foru - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 34
Son 30 gün: 122
Her zaman: 23,973
