Giriş
Follow this guide to remove and replace the motherboard in the Samsung Galaxy Note5.
Neye ihtiyacın var
Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray at the top of the phone.
Press to eject the tray. This may require some force.
Remove the SIM card tray.
Using your fingernail, push the S-Pen button until it clicks and pops out of the phone.
Remove the S-Pen.
Bu adımda kullanılan alet:Tesa 61395 Tape$8.95
Use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Using the flat end of a spudger, lift the battery connector straight up from its socket on the motherboard.
7 farklı kişi bu kılavuzu tamamladı.
