Ana içeriğe geç
Samsung Galaxy Note8 Back Cover Replacement
Neye ihtiyacın var
    1. Samsung Galaxy Note8 Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
      • Switch off your phone.
      • Prepare an iOpener for softening the adhesive on the back of the Note8.
      • Apply the iOpener on the back of the Note8 along the side with the power button.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Note8 Back Cover Replacement: adım 2, 3 resimden 1. Samsung Galaxy Note8 Back Cover Replacement: adım 2, 3 resimden 2. Samsung Galaxy Note8 Back Cover Replacement: adım 2, 3 resimden 3.
      • Use a suction handle to lift the back cover and create an opening pick to get in the gap.
      • Since the back cover is also slightly curved at the edges you want to insert the opening pick at a lower angle from underneath.
      • Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
      • Be careful not to lever the opening pick too much to avoid breaking the back cover. Rather pull with the suction handle and use the pick for cutting the adhesive.
      • Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
      • Use another pick and move it to the top corner.
      • If it's getting harder to move the pick you might need to reheat the iOpener and apply it to the back cover again.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy Note8 Back Cover Replacement: adım 3, 3 resimden 1. Samsung Galaxy Note8 Back Cover Replacement: adım 3, 3 resimden 2. Samsung Galaxy Note8 Back Cover Replacement: adım 3, 3 resimden 3.
      • Again take another opening pick and carefully move it around the corner and along the top edge.
      • Reheat with an iOpener if necessary.
      • Leave the pick at the top right corner to keep the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy Note8 Back Cover Replacement: adım 4, 3 resimden 1. Samsung Galaxy Note8 Back Cover Replacement: adım 4, 3 resimden 2. Samsung Galaxy Note8 Back Cover Replacement: adım 4, 3 resimden 3.
      • Rotate the device and start to separate the adhesive at the bottom with another opening pick.
      • Leave the pick at the bottom right corner to keep the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Galaxy Note8 Back Cover Replacement: adım 5, 3 resimden 1. Samsung Galaxy Note8 Back Cover Replacement: adım 5, 3 resimden 2. Samsung Galaxy Note8 Back Cover Replacement: adım 5, 3 resimden 3.
      • When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
      • Don't force it open. Use an iOpener to again soften the adhesive if the back cover won't come off or starts to bend.
      • Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Galaxy Note8 Back Cover Replacement: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use a pair of tweezers to disconnect the fingerprint sensor.
      • The connector might already have come off when flipping the back cover open.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung Galaxy Note8 Back Cover Replacement: adım 7, 1 resimden 1.
      • Remove the back cover.
      • To prepare for the reassembly remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
      FixBot'a Sor
      Yorum Ekle
Sonuç
If possible, turn on your phone and test the new part before installing new adhesive and resealing the phone.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
43 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
134.940 İtibar
189 adet Kılavuz yazıldı
Ekip
3Kılavuz Yorumları
My adhivsive was a pain in the but! Never fixed a phone that hard glued :O
Vidar G - Yanıt Paylaş
the separate adhesive was unneeded the replacement back cover came with adhesive
Anthony Asp - Yanıt Paylaş
So close!!!!’ I sliced the fingerprint sensor cable off, that area of the back glass was so smashed. Hopefully I can get a replacement to me by Saturday
Douglas Pocknett Jr - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 23
Son 30 gün: 121
Her zaman: 33,458
