Giriş
Use this guide to replace the display assembly including the frame of your Galaxy Note8.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
This guide involves removing the rear glass cover; you will need replacement adhesive to reattach the back cover to the phone.
Opening the Samsung Galaxy Note8 will damage the waterproof seals on the device. If you do not replace the adhesive seals, your phone will function normally, but will lose its water resistance.
Neye ihtiyacın var
Switch off your phone.
Prepare an iOpener for softening the adhesive on the back of the Note8.
Apply the iOpener on the back of the Note8 along the side with the power button.
Use a suction handle to lift the back cover and create an opening pick to get in the gap.
Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
Use another pick and move it to the top corner.
Use the flat end of a spudger to disconnect the battery connector.
Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath the battery. Reheat and reapply the iOpener as needed.
Alternatively or when the battery is blown up, you can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
Insert a SIM card opening tool into the small hole on the left side of the top edge of the phone.
Press to eject the tray.
Remove the SIM card tray from the phone.
Prepare an iOpener and apply it to the bottom part of the phone to loosen the adhesive beneath the microphone flex cable.
Use a pair of tweezers to carefully lift the microphone out of its recess and loosen it from the mid frame.
Prepare an iOpener and apply it across the phone to loosen the adhesive beneath the vibration motor at the bottom and the earpiece speaker at the top.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Follow these instructions in reverse order to reassemble your device. Apply new adhesive where necessary.
45 farklı kişi bu kılavuzu tamamladı.
10Kılavuz Yorumları
i would like to suggest a time of (52) Minutes and (36) Seconds plus thanks for the guide
check, plus you’re welcome :)
great guide!
Very excellent guide. Great pictures. Pictures must have been done in some sorta studio setting or edited for only what is needed for the illustration of every step. This was my first attempt at self repair on a cellphone, but I’m no slouch. I repair and refurbish all sorts of electromechanical devices and was once employed to do brain surgery on massive water cooled mainframe computers. Some of the same rules apply; have proven procedures, follow instructions, control your work space, and invest in the best tools. Since this was my first, I was not in a hurry. It took me all of 6 hours, but I was meticulous, repeated many steps to increase my confidence, and had all the time needed to do what I needed to do. Grateful for no longer being a slave to phone repair/insurance scams!! DIY forever!
Thanks for the great guide. Unfortunately, ifixit does not stock Note 8 parts in Australia. When I went to purchase the display assembly with frame from a parts supplier, they refused to sell me the part as they said that a number of customers have experienced the LCD not working on the new assembly after repairing their phone. The wholesaler would not honour the warranty as all screens are tested before dispatch, therefore, the LCD must have been damaged in the repair process. I could understand if the repair included installing a new screen into an existing frame but because all parts are being transferred into the new assembly and the parts available for sale all come with adhesive, is there any step where it is likely that the LCD could be damaged even if extremely careful?
