Ana içeriğe geç
Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement, Back Cover: adım 1, 1 resimden 1.
    • Switch off your phone.
    • Prepare an iOpener for softening the adhesive on the back of the Note8.
    • Apply the iOpener on the back of the Note8 along the side with the power button.
  2. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 2, 3 resimden 1. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 2, 3 resimden 2. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 2, 3 resimden 3.
    • Use a suction handle to lift the back cover and create an opening pick to get in the gap.
    • Since the back cover is also slightly curved at the edges you want to insert the opening pick at a lower angle from underneath.
    • Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
    • Be careful not to lever the opening pick too much to avoid breaking the back cover. Rather pull with the suction handle and use the pick for cutting the adhesive.
    • Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
    • Use another pick and move it to the top corner.
    • If it's getting harder to move the pick you might need to reheat the iOpener and apply it to the back cover again.
  3. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 3, 3 resimden 1. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 3, 3 resimden 2. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 3, 3 resimden 3.
    • Again take another opening pick and carefully move it around the corner and along the top edge.
    • Reheat with an iOpener if necessary.
    • Leave the pick at the top right corner to keep the adhesive from resealing.
  4. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 4, 3 resimden 1. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 4, 3 resimden 2. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 4, 3 resimden 3.
    • Rotate the device and start to separate the adhesive at the bottom with another opening pick.
    • Leave the pick at the bottom right corner to keep the adhesive from resealing.
  5. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 5, 3 resimden 1. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 5, 3 resimden 2. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 5, 3 resimden 3.
    • When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
    • Don't force it open. Use an iOpener to again soften the adhesive if the back cover won't come off or starts to bend.
    • Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
  6. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to disconnect the fingerprint sensor.
    • The connector might already have come off when flipping the back cover open.
  7. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 7, 1 resimden 1.
    • Remove the back cover.
    • To prepare for the reassembly remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  8. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement, NFC Antenna and Charging Coil Assembly: adım 8, 1 resimden 1.
    • Remove the ten Phillips #00 screws.
  9. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 9, 2 resimden 1. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 9, 2 resimden 2.
    • Use an opening pick at the top edge to get between the NFC antenna and charging coil assembly and the case.
    • Lever the top of the assembly out of the case.
  10. Samsung Galaxy Note8 NFC Antenna and Charging Coil Assembly Replacement: adım 10, 1 resimden 1.
    • Carefully pull up the complete charging coil and NFC antenna assembly.
    • The bottom left part of the assembly is slightly glued down to the frame.
Sonuç
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it is necessary.
8 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
124.510 İtibar
189 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
Excelente!!! Justo lo que estaba buscando, muchas gracias!!
zzuftt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 77
Her zaman: 8,617
