Ana içeriğe geç
Samsung Galaxy Player 4.2 Battery Casing Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Samsung Galaxy Player 4.2 Battery Casing Replacement, Battery: adım 1, 2 resimden 1. Samsung Galaxy Player 4.2 Battery Casing Replacement, Battery: adım 1, 2 resimden 2.
    • Use your finger to press in the battery cover tab on the upper right hand corner of the back of the device.
    • Pry the battery cover off the device by pressing in and lifting up.
    • When reassembling, align the top portion of the back cover to the top of the device and press down until it clicks into place.
  2. Samsung Galaxy Player 4.2 Battery Casing Replacement: adım 2, 2 resimden 1. Samsung Galaxy Player 4.2 Battery Casing Replacement: adım 2, 2 resimden 2.
    • Press your finger into the groove on the bottom left hand side of the battery.
    • Pry the battery out by lifting your finger up.
  3. Samsung Galaxy Player 4.2 Battery Casing Replacement, Battery Casing: adım 3, 2 resimden 1. Samsung Galaxy Player 4.2 Battery Casing Replacement, Battery Casing: adım 3, 2 resimden 2.
    • Remove the six 2.0mm Phillips #0 screws from the battery casing.
  4. Samsung Galaxy Player 4.2 Battery Casing Replacement: adım 4, 3 resimden 1. Samsung Galaxy Player 4.2 Battery Casing Replacement: adım 4, 3 resimden 2. Samsung Galaxy Player 4.2 Battery Casing Replacement: adım 4, 3 resimden 3.
    • Starting at the top, insert the plastic opening tool at the seam between the battery casing and the main body of the device.
    • Pry up, working around the seam from top to bottom.
    • The battery casing fits snuggly against the main body of the device. You may need to apply some moderate force to free it.
    • The volume button may pop out when you free the battery casing.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
88.898 İtibar
131 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
16.560 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 432
