Ana içeriğe geç
Samsung Galaxy Prevail 2 Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: adım 1, 3 resimden 1. Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: adım 1, 3 resimden 2. Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: adım 1, 3 resimden 3.
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: adım 2, 3 resimden 1. Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: adım 2, 3 resimden 2. Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: adım 2, 3 resimden 3.
    • Gently pull the battery out of the phone.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alexandra Hernandez
741 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-4, Leahy Fall 2014 USF Tampa, Team 14-4, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G4
4 Üyeler
5 adet Kılavuz yazıldı
3Kılavuz Yorumları
I just replaced the battery about a month ago after turning phone off and the turned back on it stuck on screen with samsung and the other lights stayed on
lindabuhl5729 - Yanıt
Mine doing the same
Chuck Slagel - Yanıt
"To reassemble your device, follow these instructions in reverse order" seriously?! I mean even an idiot should know that!
illy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 1,963
