Ana içeriğe geç
Samsung Galaxy Prevail 2 Home Button Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: adım 1, 3 resimden 1. Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: adım 1, 3 resimden 2. Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: adım 1, 3 resimden 3.
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: adım 2, 3 resimden 1. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: adım 2, 3 resimden 2. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: adım 2, 3 resimden 3.
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Screws: adım 3, 2 resimden 1. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Screws: adım 3, 2 resimden 2.
    • Unscrew all of the screws.
    • Be sure to set aside in a safe place.
  4. Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: adım 4, 3 resimden 1. Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: adım 4, 3 resimden 2. Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: adım 4, 3 resimden 3.
    • Insert the plastic opening tool between the silver frame and the white face of the phone to pry off the front face.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone
  5. Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: adım 5, 3 resimden 1. Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: adım 5, 3 resimden 2. Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: adım 5, 3 resimden 3.
    • With the plastic opening tool, lift up the flap to to fully open the motherboard.
  6. Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: adım 6, 3 resimden 1. Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: adım 6, 3 resimden 2. Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: adım 6, 3 resimden 3.
    • With the plastic opening tool, lift the second flap up.
  7. Samsung Galaxy Prevail 2 Home Button Replacement, Locate Home Button: adım 7, 2 resimden 1. Samsung Galaxy Prevail 2 Home Button Replacement, Locate Home Button: adım 7, 2 resimden 2.
    • Choose the motherboard side that contains the home button, as shown in the image.
  8. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Home Button: adım 8, 2 resimden 1. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Home Button: adım 8, 2 resimden 2.
    • Use the plastic opening tool to push the home button out.
    • Push the button from the face of the phone inwards as indicated in the first image.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Garrett Bowleg
469 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-4, Leahy Fall 2014 USF Tampa, Team 14-4, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 2,123
