Ana içeriğe geç
Samsung Galaxy Prevail 2 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: adım 1, 3 resimden 1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: adım 1, 3 resimden 2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: adım 1, 3 resimden 3.
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: adım 2, 3 resimden 1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: adım 2, 3 resimden 2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: adım 2, 3 resimden 3.
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: adım 3, 2 resimden 1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: adım 3, 2 resimden 2.
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: adım 4, 3 resimden 1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: adım 4, 3 resimden 2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: adım 4, 3 resimden 3.
    • Insert the plastic prying tool between the silver frame and the white face of the phone to pry off the front frame.
    • Make sure to pry around the entire frame before attempting to loosen it.
    • Push the motherboard out using your thumbs as shown
  5. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: adım 5, 3 resimden 1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: adım 5, 3 resimden 2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: adım 5, 3 resimden 3.
    • Lift the flap up using the plastic prying tool.
  6. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: adım 6, 3 resimden 1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: adım 6, 3 resimden 2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: adım 6, 3 resimden 3.
    • Lift the second flap to detach the motherboard completely.
  7. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: adım 7, 3 resimden 1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: adım 7, 3 resimden 2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: adım 7, 3 resimden 3.
    • With plastic prying tool, lift the flap connected to the camera (indicated in red) to remove it.
    • Be sure that you are looking at the back face of the motherboard.
  8. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: adım 8, 3 resimden 1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: adım 8, 3 resimden 2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: adım 8, 3 resimden 3.
    • Carefully lift and remove the camera from its position.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Alexandra Hernandez
741 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-4, Leahy Fall 2014 USF Tampa, Team 14-4, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,421
