Ana içeriğe geç
Samsung Galaxy Prevail 2 Vibrator Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: adım 1, 3 resimden 1. Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: adım 1, 3 resimden 2. Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: adım 1, 3 resimden 3.
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: adım 2, 3 resimden 1. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: adım 2, 3 resimden 2. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: adım 2, 3 resimden 3.
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: adım 3, 2 resimden 1. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: adım 3, 2 resimden 2.
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: adım 4, 3 resimden 1. Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: adım 4, 3 resimden 2. Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: adım 4, 3 resimden 3.
    • Insert the plastic prying tool between the silver frame and the white face of the phone. to pry off the front frame.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone.
  5. Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: adım 5, 3 resimden 1. Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: adım 5, 3 resimden 2. Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: adım 5, 3 resimden 3.
    • With the plastic prying tool, lift up the flap in order to fully open the motherboard.
  6. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: adım 6, 3 resimden 1. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: adım 6, 3 resimden 2. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: adım 6, 3 resimden 3.
    • With plastic prying tool, lift the flap up to divide the motherboard.
    • This will make it easier to detach the internal battery.
  7. Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: adım 7, 3 resimden 1. Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: adım 7, 3 resimden 2. Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: adım 7, 3 resimden 3.
    • With plastic prying tool, lift up the vibration motor.
  8. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Vibration Motor: adım 8, 1 resimden 1.
    • With the soldering iron remove the solder attaching the vibration motor to the motherboard.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Garrett Bowleg
469 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-4, Leahy Fall 2014 USF Tampa, Team 14-4, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,043
