Giriş
By following this guide you should be able to replace the headphone jack in 10-20 minutes. By replacing the headphone jack, you will fix any headphone related audio issues such as static, muffled sounds, or poor earphone audio quality.
Neye ihtiyacın var
Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
Bir başkası bu kılavuzu tamamladı.
