Ana içeriğe geç
Samsung Galaxy Prevail Rear Camera Lens Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Prevail Rear Camera Lens Replacement, Rear Camera Lens: adım 1, 1 resimden 1.
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Camera Lens Replacement: adım 2, 1 resimden 1.
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Camera Lens Replacement: adım 3, 1 resimden 1.
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Camera Lens Replacement: adım 4, 1 resimden 1.
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Camera Lens Replacement: adım 5, 1 resimden 1.
    • Replace the secondary rear panel which has the camera lens attached.
Sonuç
Ricardo Zuloaga
537 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G6
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 313
