Ana içeriğe geç
Samsung Galaxy Prevail Rear Speaker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Prevail Rear Speaker Replacement, Rear Speaker: adım 1, 1 resimden 1.
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Speaker Replacement: adım 2, 1 resimden 1.
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Speaker Replacement: adım 4, 1 resimden 1.
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The motherboard will now be accessible.
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Speaker Replacement: adım 5, 2 resimden 1. Samsung Galaxy Prevail Rear Speaker Replacement: adım 5, 2 resimden 2.
    • Using the spudger, carefully lift upward to remove the speaker assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ricardo Zuloaga
537 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G6
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 254
